Edgar J. Kaiser
Certified Consultant
3 years ago
Apr 16, 2022, 6:10 a.m. EDT
Tony,
I do not really understand your setup. You apply the 1000V potential on the top sphere and on the connections between the resistors.
Shouldn't it only be applied to the sphere?
You set up a time dependent study step without a time setting. Shouldn't this be a stationary study?
And in ec all domains must have at least a very small conductivity, also the air domain, otherwise the solver won't converge.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Tony,
Cheers
Edgar
3 years ago
Apr 16, 2022, 6:47 a.m. EDT
Hey Edgar,
Thanks for your time and reply!
The truth is that I haven't designed niether the geometry nor the time dependency of the study but I am only told to add materials, boundaries and compute. My pure guess of why "time-dependent" is that I am asked to generate plots of the step and frequency response simulations of the divider which might need a time dependent study.
However, I applied 1000 V on the connections between the resistors because that made the solver converge in 2-3 seconds. When I only applied 1000 to the sphere, then the simulation took 30 mins to be completed and the results showed zero potential everywhere but the sphere. This delay could be due to the convergence problem that you have mentioned about the insulators having 0 condictivity.
Now,
1. I will remove the boundaries from the connections and introduce some condictivity to air and the plexiglass tube.
2. check the time setting
3. compute
Regards
Tony
Hey Edgar,
Now,
3. compute
Regards
Tony
Edgar J. Kaiser
3 years ago
Apr 16, 2022, 8:05 a.m. EDT
Updated:
3 years ago
Apr 16, 2022, 8:28 a.m. EDT
I recommend to do a stationary study first to check plausibility. A time dependent study may not converge without ramping up the potential BC.
Edgar J. Kaiser
www.emphys.com
3 years ago
Apr 23, 2022, 3:46 a.m. EDT
Hi Edgar,
I disabled the time dependent study and added a stationary study to my model. Still no electric potential is appearing in the potential plots. Could you please have a look at the attached model and give me some advice on how to proceed?
Regards
Tony
Hi Edgar,
Regards
Tony
Edgar J. Kaiser
3 years ago
Apr 23, 2022, 4:43 p.m. EDT
There is no solver for the stationary step.
Edgar J. Kaiser
www.emphys.com
3 years ago
Apr 25, 2022, 12:35 p.m. EDT
Yeah, I completely missed that. The stationary case is now working well and I am getting a potential distribution as shown in the figure below.
[drive.google.com/file/d/15IGwEW2AKxVwxwtsTgMC-dJ8bdOtWji-/view?usp=sharing]
For the time dependent study, I am using this function V =1000*(1-exp(-t/tau)) for my electric potential BC but the simulation is not converging. It took 30 mins to complete it and it is giving zero potential everywhere. Any idea why it is taking so long time ? I am not sure if the boundary conditions I have applied cause that kind of convergence problem. Could you please take a look at the attached model and see if the boundaries look good?
Edgar J. Kaiser
3 years ago
Apr 25, 2022, 4:03 p.m. EDT
You don't have any output times in the time dependent step. If the stationary study converges the BCs should be ok.
You will probably need to play with the time stepping to get the time dependent solver to run.
Edgar J. Kaiser
www.emphys.com
