Liquid surface relief in сonjugated task of heat transfer and hydrodynamics
Posted May 19, 2022, 10:39 a.m. EDT Fluid & Heat, Heat Transfer Version 5.6 0 Replies
I want to calculate a surface relief of liquid in which a heat source is located at some depth. There is a jet from the source and it impacts on the surface. I try to use the Level Set Interface, Heat Transfer in Liquids Interface, but the solution doesn't converge. Do you know some similar examples to calculate the surface relief in liquid with heat transfer? Thanks.
Hello Юлия Константиновна Руденко
