Exporting data for multiple Cut planes
Hi all,
I'm modeling a mixer and I would like to export concentration profiles at different cut-planes along the channel. I can do a single cut plane export with:
Defining: Data Sets -> Cut Plane - then...
... Export -> Data -> Data set -> Output...
How can I do the same for multiple cut planes - when I try to use the same procedure (under Data Sets -> Cut Plane ...) defining multiple Cut planes via 'Additional parallel planes' options it doesn't work. For the concentrations I get only NaN-s.
Thank you in advance for your generous help!
Izidor
3 Replies Last Post Mar 13, 2015, 10:26 a.m. EDT
Posted: 1 decade ago Aug 21, 2012, 6:09 a.m. EDT
If anybody knows how do this, please help.
It will save a lot of time, so I don't have to do it manually, Cut Plane, by Cut Plane.
I'm very much grateful for any help...
If anybody knows how do this, please help. It will save a lot of time, so I don't have to do it manually, Cut Plane, by Cut Plane. I'm very much grateful for any help...
Posted: 1 decade ago Jan 10, 2013, 2:42 p.m. EST
Did anyone ever figure this out? I'm having the same issue.
I used "additional parallel planes" to make about 100 planes, I want the average of each discretely, however it just takes a lump average of all of them.
As you can imagine the other way would be TEDIOUS!
Did anyone ever figure this out? I'm having the same issue. I used "additional parallel planes" to make about 100 planes, I want the average of each discretely, however it just takes a lump average of all of them. As you can imagine the other way would be TEDIOUS!
Yogesh Kumar Murugesan
Posted: 1 decade ago Mar 13, 2015, 10:26 a.m. EDT
I know years since the questions have been posted. Just thought of posting the answer for anybody who might have the same question in the future.
Comsol blog has posted a solution the problem recently.
www.comsol.com/blogs/maximum-evaluations-on-parallel-sections/
I know years since the questions have been posted. Just thought of posting the answer for anybody who might have the same question in the future. Comsol blog has posted a solution the problem recently. http://www.comsol.com/blogs/maximum-evaluations-on-parallel-sections/
