Turbulence variable residual does not converge
Posted Jul 24, 2022, 7:43 p.m. EDT Fluid & Heat, Computational Fluid Dynamics (CFD), Mesh Version 6.0 0 Replies
I am running a steady state simulation considering fluid flow and all forms of heat transfer (conduction, convection, and radiation).
I have struggled a lot to make my case converge (even after 6 days does not work). My mesh should be good (minimum skewness of 0.01 with an average of 0.66 with about ~6 mil elements). The operating pressure is 30 atm, N2 as the working fluid. My domain has sliding walls with 400 RPM of rotational speed.
How can I reduce the residual for the turbulence variable (please see attached)? I have increased the # of iterations and reduced the damping factor. Also, I explored different segregated solvers. Yet, no luck:/
I am not able to share my geometry but I appreciate any possible ideas/hints.
Thank you!
Hello Hooman E
