How to fill a 2D geometry with simple points
Hello, I would like to know if there is a practical way to fill a 2D point object with simple points.
The following is an attempt to do this using the array option (screenshots in imgur link). In this case, I would like to keep only the points that are inside the circle and exclude the others (inside the area in red).
Link to screenshots (https://imgur.com/a/0cQGvKp)
1 Reply Last Post Aug 16, 2022, 9:30 p.m. EDT
Posted: 3 years ago Aug 16, 2022, 9:30 p.m. EDT
Yes, you can do this. Create your points with the help of the array tool. Then do a boolean Union of them, so they can be treated as one object. Then create your other 2D object. Then do an intersection of that object with the (unioned) array of points.
