How to model the imaginary square domain ?
I want to take a square simulation domain with the cylinder located at its center.How to set the boundary of the square field as a dashed line?Any suggestion will be appreciated.
2 Replies Last Post Oct 13, 2022, 11:33 p.m. EDT
Posted: 2 years ago Aug 28, 2022, 11:43 a.m. EDT
Updated: 2 years ago Aug 28, 2022, 11:44 a.m. EDT
I suggest you provide much more information. Let's start at the beginning: what physics problem are you trying to solve?
Posted: 2 years ago Oct 13, 2022, 11:33 p.m. EDT
Thank you. I want to solve the problem that a metal cylinder is polarized when it is put into an electrolyte solution and an electric field is applied. I want to study the dynamic problem of the electric double layer and the induced charge around the metal cylinder. Now the model has been established, which is a transient model. But the final calculation results do not change after I apply different times, and I only get a look of the electric double layer in a stable state. I can't see the change process of the electric double layer establishment.
