Magnus Ringh
COMSOL Employee
2 years ago
Sep 5, 2022, 8:42 a.m. EDT
Hi Lampros,
To define seconds, use [s]
or [second]
; [sec]
is not a valid unit in COMSOL Multiphysics. SI prefixes are also supported, such as [ms]
for milliseconds, as well as [min]
, [h]
, and [a]
for minutes, hours, and years, respectively. See the user documentation for a full list of supported unit systems, units, and SI prefixes.
Magnus
Hi Lampros,
To define seconds, use `[s]` or `[second]`; `[sec]` is not a valid unit in COMSOL Multiphysics. SI prefixes are also supported, such as `[ms]` for milliseconds, as well as `[min]`, `[h]`, and `[a]` for minutes, hours, and years, respectively. See the user documentation for a full list of supported unit systems, units, and SI prefixes.
Magnus
Lampros Papadopoulos
BFH Praktikant
2 years ago
Sep 5, 2022, 9:05 a.m. EDT
Hello Magnus,
First of all, thank you for the quick responce. Yes, I have tried that too. That does not seem to be the problem. Even if I change [sec] to [s]. I get the exact same error:
"Error in multiphysics compilation. Syntax error in expression. - Expression: [s] - Subexpression: [s] - Position: 1"
Lampros
Hello Magnus,
Lampros
Magnus Ringh
COMSOL Employee
2 years ago
Sep 5, 2022, 9:29 a.m. EDT
Hi Lampros,
Then there is some other issue with the expression. I think you need to display the entire expression for us to be able to pinpoint what could be wrong.
Magnus
Hi Lampros,
Magnus
Dave Greve
Certified Consultant
2 years ago
Sep 5, 2022, 1:41 p.m. EDT
The argument for the function Vin must be dimensionless. Try using Vin(t/1[s]).
Jeff Hiller
COMSOL Employee
2 years ago
Sep 6, 2022, 4:05 p.m. EDT
Hello Lampros,
The problem is your Variable 3 node, which you use to define a variable t as [sec]. In a time-dependent analysis, t is automatically defined as time, so you do not need to create this Variable 3 node at all, and you can -and should- remove it; as Magnus mentioned already [sec] is not a valid expression, it's not even the right notation for "second", [s] is ; this is causing the error. When you remove that node, the compilation error disappears.
With that said, I have not let your model run to completion, so there may be other issues with your set-up.
Jeff Hiller
Hello Lampros,
BFH Praktikant
2 years ago
Sep 8, 2022, 8:35 a.m. EDT
Ok, thank you all very much for your replies! Will look into it.
