Error while compiling the java file
Hi, I am trying to open my simulation done on comsol v5.6 on comsol v5.1. I find that the only solution is to save my file as java file and compile it in the older version of comsol and open it as class file on comsol v5.1. However, while trying to compile the java file I got the below error: error: cannot find symbol model.component().create("comp1", true); ^ symbol: method component() location: variable model of type Model
Also, here is some of my java file (saved from comsol 5.6) import com.comsol.model.*; import com.comsol.model.util.*;
/** Model exported on Sep 10 2022, 13:44 by COMSOL 5.6.0.280. */ public class Simulation1 {
public static Model run() { Model model = ModelUtil.create("Model");
model.modelPath("C:\\Users\\Omar\\Desktop\\Comsol");
model.label("Simulation1.mph");
model.param().set("a_Wood", "0");
model.param().set("b_Wood", "10[mm]");
model.param().set("a_Insulation", "17[mm]");
model.param().set("b_Insulation", "78.5[mm]");
Any suggestion will be appreciated.
Thank you!
0 Replies Last Post Sep 10, 2022, 7:58 a.m. EDT
Hello Omar Osman
