COMSOL keeps shutting down amid running
Posted Sep 14, 2022, 2:01 p.m. EDT Version 5.6 0 Replies
Hello, the software console keeps shutting down amid running. The following report was generated in the most recent incident. Sometimes it just shuts down without any notification or error report.
Could you please help explain why? Thanks much.
A fatal error has been detected by the Java Runtime Environment:
EXCEPTIONACCESSVIOLATION (0xc0000005) at pc=0x00007ff8a28bc4f3, pid=13600, tid=0x0000000000001db0
JRE version: OpenJDK Runtime Environment (8.0265-b01) (build 1.8.0265-b01) Java VM: OpenJDK 64-Bit Server VM (25.265-b01 mixed mode windows-amd64 compressed oops) Problematic frame: C 0x00007ff8a28bc4f3
Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
If you would like to submit a bug report, please visit: http://bugreport.java.com/bugreport/crash.jsp The crash happened outside the Java Virtual Machine in native code. See problematic frame for where to report the bug.
** --------------- T H R E A D ---------------
Current thread (0x00000218f8bc3000): JavaThread "Blocking-0" [threadinnative, id=7600, stack(0x0000009bf6800000,0x0000009bf6c00000)]
siginfo: ExceptionCode=0xc0000005, ExceptionInformation=0x0000000000000008 0x00007ff8e29bc4f3 *
Hello Kai Zheng
