Lumped port help
Georgios Chatzidrosos
I am trying to simulate a simple model of a co-planar waveguide on top of a substrate, as seen in the attached file. Whenever I try to compute my result I get the error:
Uniform lumped port should be placed between two conductive boundaries. - Feature: Uniform Element 2 (ue2) - Feature: Uniform Element 1 (ue1)
I do not understand why that happens. I made sure to select the neighbouring boundaries as PEC and set up my Lumped ports based on option two from here: https://www.comsol.com/blogs/modeling-coplanar-waveguides
Could you kindly explain to me what I am doing wrong?
Best Georgios
1 Reply Last Post Oct 20, 2022, 11:49 a.m. EDT
Posted: 2 years ago Oct 20, 2022, 11:49 a.m. EDT
  1. Your PEC (set by default) zy planes at x = -2250 µm and x = +2250 µm are shorting out your lumped ports. So those planes should probably not be specified as PEC.
  2. There may still be other important issues in your model that need to be addressed, but fixing the above will eliminate the error message you reported.
1. Your PEC (set by default) zy planes at x = -2250 µm and x = +2250 µm are *shorting out* your lumped ports. So those planes should probably not be specified as PEC. 2. There may still be other important issues in your model that need to be addressed, but fixing the above will eliminate the error message you reported.
