Sep 12, 2012, 2:39 p.m. EDT
you should not wrok on the plots, but on the data sets and the export partial data sets, or create cut lines, planes etc and export those, here you can define more about ranges, and how data is interpolated. Check the doc (in particular the latest version ...)
Sep 12, 2012, 4:56 p.m. EDT
Thanks for the suggestion Ivar! This definitely sent me in the right direction.
But now I think I am (almost) back to where I started.
I have created a Edge 2D data set to be on the model edges I want, and can export the expressions I desire over this geomerty.
But I still have two problems:
1. I cannot seem to have comsol NOT include the x and y coordinate points in the spreadsheet output and I see no option to change this behavior. All I want is angle (phi) and calculated data. (so I can output sorted data sorted by phi)
2. I still cannot really set "resolution" as I want (to force a certain angle step of cylindrical_system.phi). Changing the lagrange element order is of no use to me (at least that which I understand yet)
Are either of these issues reconcilable?
Sep 12, 2012, 5:43 p.m. EDT
Update,
I believe I am one step closer to my goal.
I have found that under the export tab, I can indeed select to evaluate the expression at manual points via 'Points to evaluate in' but here is the root of my original question...
Am I forced to evaluate the points in terms of x,y coordinates, or is it possible to 'evaluate' the data set in terms of my cylindrical coordinate system? (or some other system other than simple x,y for that matter)
If the later were true, I could simply tell the export to evaluate my edge for given phi values which would go back to the cylindrical coordinate system and determine what x,y point that corresponds to. This should work since Comsol would have the edge (r) and my input phi values, so it could completely describe a point to evaluate on.
From what I have gathered though, in order to do what I want, I must MANUALLY create these x,y points and feed them into comsol, which will then evaluate to give me my desired values.
Is this correct?
Will
Update,
Is this correct?
Will
Sep 13, 2012, 10:13 a.m. EDT
Just in case this is useful to anyone, this is how I solved my problem:
1. Insert a Data Sets > Parameterized Curve 2D
Here define the x and y points as 'radius of interest'*cos and likewise for sin.
Also define the range of angle I want via Minimum and Maximum parameter values.
2. Set resolution in terms of number of points I want in the Resolution entry field.
3. In the data export, leave 'Points to evaluate in' as 'Data set'
Done!
Now I have to say, I still think there should be functionality where instead of inputting an expression, this could somehow be done in the Data Sets > Edge 2D with extra options for resolution and what points to evaluate based on the type of geometry found (eg. phi for circular geometry; x and y for rectangular geometry...) but I suppose this is more work for developers ;)
Will
Done!
Will
Sep 15, 2012, 5:23 a.m. EDT
I'm not sure its general enough, if your shape is elliptic, which phy to use ? and why not something else ?
when you write it out you know what you have, in all generality
