2 years ago
Nov 2, 2022, 3:14 a.m. EDT
Dear Sandy,
I don't think it is very different between i-core and xeon-core. The number of cores and speeds are the most important. The differences between i-core and xeon-core are that i-cores are not designed for last super long and staple. Also, the workstations have special ram. But, I think your PC is good enough for COMSOL. I am using Dell workstation dual gold xeon and 64GB Ram. It is little faster than i5 (6 year old) with 32 GB. To speed up calculation, you should consider symetrial geometry then reduce the size to reduce the number of DOF to speed up. It is much better than investing on computer.
Dear Sandy,
Walter Frei
COMSOL Employee
2 years ago
Nov 3, 2022, 9:51 a.m. EDT
For more details on this topic, see also:
https://www.comsol.com/support/knowledgebase/866
as well as:
https://www.comsol.com/blogs/much-memory-needed-solve-large-comsol-models/
With regards to the Xeon Gold processor, these have six, or eight (in the newer generation) memory channels, and should only be used in at least dual-CPU configurations. You should get a speed upgrade if you upgrade such a system so that all memory channels are filled.
as well as:
Dave Greve
Certified Consultant
2 years ago
Nov 3, 2022, 3:30 p.m. EDT
It's worth looking into why your calculation takes a long time. If the calculation is going out of core there may be a big payoff for adding more memory. Or looking very carefully at meshing and symmetries to see if you can reduce the problem size.
It's worth looking into *why* your calculation takes a long time. If the calculation is going out of core there may be a big payoff for adding more memory. Or looking very carefully at meshing and symmetries to see if you can reduce the problem size.
