Sep 17, 2012, 8:21 a.m. EDT
you can add the circuit physics and add terminals to your model.
Cheers
Edgar
Cheers
Edgar
Sep 17, 2012, 9:13 a.m. EDT
but are you interestied in the transient or the steady state sinus type excitation ?, if the time transient is of interest, use a time stepping solver, and a A0*sinus(omega[1/s]*t) type BC excitation, if it is the steady state sinus excitation, you should consider the harmonic development of your equations, hence use the frequency domain solver and set your BC to the amplitude A0 only without any "t" dependnece. Check the equations of the main physics for the difference in PDE development betwqeen time series and frequency domain
Sep 18, 2012, 1:47 a.m. EDT
Hi!
In 3D you can use in V4.3 also single-turn coil domain or multi-turn coil domain, but single-turn coil domain only with stationary or frequency domain, since this feature will use MEF formulations.
Multi-turn coil domain seems to work also in transient.
But read carefully the doc, because definition is not simple, if you have complex geometry (numerical coil type).
Ralf
Hi!
Ralf
Sep 20, 2012, 5:07 a.m. EDT
Thanks to all to reply me,
And I have got the way to apply current in coil,.
and ofcourse your comments is very use full to do approach,
Thanks again.
Chirag
Thanks again.
Chirag
Sep 20, 2012, 8:38 a.m. EDT
helllo chirag can you tel me how the procedure is
kishore Naik Mude
kishore Naik Mude
Sep 21, 2012, 4:33 a.m. EDT
hello kishore,
First of all i would like to know whether your coil is multi turn or single turn?
If you are using AC/DC module then go for magnetic field solution and the you will find the option for single turn or multiturn. and set as per your requirement and check for all parameters in setting window. you may find it,.
I am not sure whether this answer helps you or not, but I done by this way.
Chirag
hello kishore,
Chirag
Sep 21, 2012, 4:39 a.m. EDT
thanks chirag ....i find it from AC/DC coil ....i am simulating the two coils which are parallel to each other and there is a gap between the two coils and medium is air ...should i apply excitement of single turn coil to both coils ...i am doing so ..i dont know it is right or wrong and another thing is should i give infinite elements to the coils
pls suggest
thanks in advance
kishore Naik Mude
pls suggest
thanks in advance
kishore Naik Mude
