Comsol 4.2a, RF MODULE, PML
Dear All,
I have question about this module which I uploaded.
Medium is air, substrate is glass, and I want to put some dipole on that glass. My question is about PML.
As I know, I should put always same material PML and adjoining medium becuase of the discontinuity in refractive indices.
But what to do with this configuration which I uploaded?
It is easy to set up one half of PML is medium, one half is substrate, but what will happened between two halves of the PML ? Does any of you done these simulations? Is there some strong influence of that on results??
Thank you for any answer.
4 Replies Last Post Sep 21, 2012, 4:11 a.m. EDT
Posted: 1 decade ago Sep 20, 2012, 3:57 a.m. EDT
I would suggest to completely surround the substrate with the medium and keep a distance of at least a wavelength to the PML. And you can always try different setups and compare the results. That's the beauty of computer models, right?
Cheers
Edgar
Hi, I would suggest to completely surround the substrate with the medium and keep a distance of at least a wavelength to the PML. And you can always try different setups and compare the results. That's the beauty of computer models, right? Cheers Edgar
Posted: 1 decade ago Sep 20, 2012, 4:42 a.m. EDT
Cheers
Edgar
HEllo Edgar,
Thank you very much on answer.
I am new so I don't know yet for these tricks.
Nikola
[QUOTE] Hi, I would suggest to completely surround the substrate with the medium and keep a distance of at least a wavelength to the PML. And you can always try different setups and compare the results. That's the beauty of computer models, right? Cheers Edgar [/QUOTE] HEllo Edgar, Thank you very much on answer. I am new so I don't know yet for these tricks. Regards, Nikola
Posted: 1 decade ago Sep 20, 2012, 4:36 p.m. EDT
That's the right way to do it. It's not a problem to contact two PMLs with different materials.
[QUOTE] It is easy to set up one half of PML is medium, one half is substrate, but what will happened between two halves of the PML ? [/QUOTE] That's the right way to do it. It's not a problem to contact two PMLs with different materials.
Posted: 1 decade ago Sep 21, 2012, 4:11 a.m. EDT
Thank you very much Alexander on your answer, it is very very helpful.
Nikola
[QUOTE] [QUOTE] It is easy to set up one half of PML is medium, one half is substrate, but what will happened between two halves of the PML ? [/QUOTE] That's the right way to do it. It's not a problem to contact two PMLs with different materials. [/QUOTE] Thank you very much Alexander on your answer, it is very very helpful. Regards, Nikola
