Converge Issues for Comsol
Posted Nov 25, 2022, 12:34 a.m. EST Fluid & Heat, Chemical, Modeling Workflow 0 Replies
I have some issues with COMSOL and I need help. I hope someone can provide the help.
First, I have two independent models (fluid flow&heat exchange + fluid flow in porous media (I set constant parameters to avoid the connection to the heat exchange)). If I run the models independently, the models are perfectly converge. However, when I run all together, the combination has converge issue although they are independently.
I appreciate if anyone can provide some hints or explain the reasons.
Hello William Nguyen
