shell-beam vs solid for eigenanalysis
I created a table based on using either solid interface or shell-beam interface. Bottom boundaries/points of the solid legs/beams are fixed.
I expect both should result in closely agreed mode frequencies. However, the first and second mode frequencies are considerably different.
Is there anything wrong in the model?
2 Replies Last Post Dec 1, 2022, 9:07 p.m. EST
Posted: 2 years ago Nov 28, 2022, 7:19 a.m. EST
The setting for Connected region in Shell-Beam Connection is wrong. Try Distance (automatic) instead.
Henrik Sönnerlind
COMSOL
The setting for *Connected region* in *Shell-Beam Connection* is wrong. Try *Distance (automatic)* instead.
Posted: 2 years ago Dec 1, 2022, 9:07 p.m. EST
Thank you.
Thank you.
