Save Probes Data As A TXT File
How can I save probes data as a txt file? for instance,
Iteration num. Probe 1 1 0.123 2 0.164 3 0.194 ...
Thank you very much!
p.s. How about in case of cluster sweep mode? (distributed parametric sweep) For instance,
Node 1 Node 2 Iteration num. Probe 1 Iteration num. Probe 1 1 0.123 1 0.162 2 0.164 2 0.121 3 0.194 3 0.113
Help me please!
Young Jin
1 Reply Last Post Feb 14, 2023, 8:19 a.m. EST
Magnus Ringh COMSOL Employee
Posted: 2 years ago Feb 14, 2023, 8:19 a.m. EST
Hi Young,
In the Settings window for a probe, you can specify an output table for the probe values under Table and Window Settings. From that table, you can then export the data to a text file (*.txt).
Hi Young, In the **Settings** window for a probe, you can specify an output table for the probe values under **Table and Window Settings**. From that table, you can then export the data to a text file (*.txt).
