Unable to view material properties
Dear Sir,
I am unable to view the properties of certain materials. Ex silicone.
When i run the simulation using silicone it works perfectly indicating that the material has inbuilt properties but since i am unable to view them i cannot ascertain if the material properties are correct. It would be of great help if you can tell me how I can view the values.
Thanking you in advance,
Vijay.
1 Reply Last Post Oct 2, 2012, 2:45 p.m. EDT
Posted: 1 decade ago Oct 2, 2012, 2:45 p.m. EDT
normally you have a plot function for the "functional" material parameters, but you need to go to the "function definition" of the material "sub node". Note that the units do not appear in the graphs so you need to go back to the main material node to check the units there
Hi normally you have a plot function for the "functional" material parameters, but you need to go to the "function definition" of the material "sub node". Note that the units do not appear in the graphs so you need to go back to the main material node to check the units there -- Good luck Ivar
