How can I get non-uniform mesh?
For example, suppose I need to mesh a sphere with tetrahedral. I want the center is very dense, while the outer surface is coarser. What do I do?
I tried the edge distribution, but it does not reduce the element number much.
Thanks in advance.
1 Reply Last Post Oct 3, 2012, 2:53 a.m. EDT
Posted: 1 decade ago Oct 3, 2012, 2:53 a.m. EDT
you can add one or several "layers" (check the geoemtry node), hence get a sphere inside a sphere ... then change the desired mesh density per domain
Hi you can add one or several "layers" (check the geoemtry node), hence get a sphere inside a sphere ... then change the desired mesh density per domain -- Good luck Ivar
