How to compute the torque ripple
I'm currently working on the optimization of a electric motor. I'm wondering how can I measure the torque ripple at each iteration of my design, to feed this value as an objective in my optimization study.
Thank You!!
2 Replies Last Post Mar 23, 2023, 8:55 a.m. EDT
Philipp Buchsteiner COMSOL Employee
Posted: 2 years ago Mar 15, 2023, 7:30 a.m. EDT
Dear Thomas Clayson,
in our example of a motor parameter optimization it is shown how to maximize for both the average torque over an electrical period and to maximize the minimum torque: https://www.comsol.com/model/parameter-optimization-of-an-electric-motor-101031
You may also find our archived webinar about multiphysics motor modelling and optimization helpful, which contains a simple approach to minimize the torque ripple: https://www.comsol.de/events/webinar/designing-efficient-electric-motors-with-multiphysics-simulation-108381
Feel free to contact our support as well if you have any further questions.
Kind regards, Philipp Buchsteiner
Dear Thomas Clayson, in our example of a motor parameter optimization it is shown how to maximize for both the average torque over an electrical period and to maximize the minimum torque: https://www.comsol.com/model/parameter-optimization-of-an-electric-motor-101031 You may also find our archived webinar about multiphysics motor modelling and optimization helpful, which contains a simple approach to minimize the torque ripple: https://www.comsol.de/events/webinar/designing-efficient-electric-motors-with-multiphysics-simulation-108381 Feel free to contact our support as well if you have any further questions. Kind regards, Philipp Buchsteiner
Posted: 2 years ago Mar 23, 2023, 8:55 a.m. EDT
Thanks for you repply! I'm using a auxillary sweep that rotates the rotor for one electrical period for each iteration of the topology optimization. I'm trying to defined a variable called Tav which represents the torque average, from the auxilary sweep. This variable is defined as:
Tav = sum(with(i,rmm.Tark_1),i,1,nsol)/nsol
Unfortunatly this doesn't work when I try to use this as an objective function. I have the following error:
Sensitivity analysis does not support control variables in the constraint Jacobian.
Do you know what I'm doing wrong? How can I compute the Tav with the auxilary sweep?
Thanks for you repply! I'm using a auxillary sweep that rotates the rotor for one electrical period for each iteration of the topology optimization. I'm trying to defined a variable called Tav which represents the torque average, from the auxilary sweep. This variable is defined as: Tav = sum(with(i,rmm.Tark_1),i,1,nsol)/nsol Unfortunatly this doesn't work when I try to use this as an objective function. I have the following error: Sensitivity analysis does not support control variables in the constraint Jacobian. Do you know what I'm doing wrong? How can I compute the Tav with the auxilary sweep?
