Comsol Results time
Deiaaldeen Mohammed Khaleel
greeting, I have made a simple spiral heater that heats small metal. i got the results but i want to know after how much time i got this tempreture. so if i need to know the tempreture after 10 minutes for example what should i do ?
2 Replies Last Post Mar 17, 2023, 8:44 a.m. EDT
Posted: 2 years ago Mar 17, 2023, 5:21 a.m. EDT
If it is a stationary study the result shows the situation after infinite time. If you want a specific time you must run a time dependent study.
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Posted: 2 years ago Mar 17, 2023, 8:44 a.m. EDT
Updated: 2 years ago Mar 17, 2023, 8:44 a.m. EDT
thank you very much, i have another question if you don't mind. I used a layers for my air domain and i specified the layer as infinite element domain but when i connect the both ends of my coil to the wall of air domain i can not specify the output of the coil !
>If it is a stationary study the result shows the situation after infinite time. If you want a specific time you must run a time dependent study. thank you very much, i have another question if you don't mind. I used a layers for my air domain and i specified the layer as infinite element domain but when i connect the both ends of my coil to the wall of air domain i can not specify the output of the coil !
