Particle Tracing (the stored trajectories have the wrong dimension)
I have a model in comsol 4.3 with a 3D and a 2D geometry.
The model calculate fluid velocities in the 2D geometry.
I added the 'Particle Tracing for fluid flow' physics to the 2D geometry but after the solution is computed I get a error message:
-Dimension: 3
-Plot: traj1 (Particle trajectories).
To be able to visualize the trajectories, I have to create a 3D Plot Group
The trajectories are plotted in 3D with the z-direction being time.
I would like to visualize the trajectories in my 2D geometry. (It works if I remove the 3D geometry but I need it to get a correct simulation of the fluid velocity).
Does anybody know how I could do that?
2 Replies Last Post Oct 28, 2014, 1:29 p.m. EDT
Hello Sophie Loire
Posted: 1 decade ago Oct 28, 2014, 1:16 p.m. EDT
Hi Sophie,
I have the same problem in particle trajectory in 2D/3D model. Have you solve this problem?
Thanks.
Hi Sophie, I have the same problem in particle trajectory in 2D/3D model. Have you solve this problem? Thanks.
Posted: 1 decade ago Oct 28, 2014, 1:29 p.m. EDT
I haven't worked on this in a long time but what I did then was to export the results and plot with matlab...
