Oct 23, 2012, 1:28 a.m. EDT
if you do not change the geometry you can add several parameters to sweep under the Solver node continuation tab, check the doc
Oct 23, 2012, 6:23 p.m. EDT
thanks Ivar,
I tried to do so and added two parametric sweeps under one study but it only counts for one of them.
thanks for your help
ASAL
thanks Ivar,
ASAL
Oct 24, 2012, 12:58 a.m. EDT
I'm not sure if the option is there in 4.2 => Sweep type: Specific combination, or All combination, that might be your issue
Nov 5, 2012, 9:39 p.m. EST
thanks Ivar, that has been solved, I was making a silly mistake.
just another question: I put a time dependent water temperature as my inlet temperature at the inlet of pipe but now need to change it to heat flux (W/m) but do not get reasonable answer for that. have you got any hint regarding this issue?
thanks for all your help
ASAL
ASAL
Nov 6, 2012, 12:41 a.m. EST
if you add a "t" you are adding some multiplier in "seconds" so you whould write 300[K]+4[K/s]*t as t has y default units of [s] the unit issue would be right
But I didnt catch yu heat flux issue, I need to understand in which dimensions you are worling to. You can change your temp boundary to a heat flux boundary and put a time dependent heat flux
