Jeff Hiller
COMSOL Employee
2 years ago
May 26, 2023, 8:55 a.m. EDT
Updated:
2 years ago
May 26, 2023, 9:59 a.m. EDT
Hello Abdelrazik,
This tutorial illustrates two different approaches you can take. The following blog posts may be useful to you as well: Modeling irregular shapes..., How to use interpolated material data... and Generating a simulation mesh.... Yet another approach consists in using a third party tool to generate the mesh and importing that mesh into COMSOL.
PS: 5.2 is a rather old version of COMSOL, and there have been a number of enhancements made to the software since then, so not I am not sure that all techniques presented in these resources are available to you.
Jeff Hiller
Hello Abdelrazik,
[This tutorial](https://www.comsol.com/model/pore-scale-flow-488) illustrates two different approaches you can take. The following blog posts may be useful to you as well: [Modeling irregular shapes...](https://www.comsol.com/blogs/modeling-irregular-shapes-how-to-import-curve-data-and-loft-a-solid/), [How to use interpolated material data...](https://www.comsol.com/blogs/how-to-use-interpolated-material-data-to-model-irregular-geometries/) and [Generating a simulation mesh...](https://www.comsol.com/blogs/generating-a-simulation-mesh-of-a-femur-from-3d-data/). Yet another approach consists in using a third party tool to generate the mesh and importing that mesh into COMSOL.
2 years ago
Jun 8, 2023, 1:41 p.m. EDT
Dear Jeff,
I would like to understand how the .dxf file was created in COMSOL's pore scale example using an SEM image. I'm currently attempting to convert a specific .png image into a model where I can simulate diffusion in the black (porous) and white (non-porous) regions. However, I've encountered a problem during the conversion process. When I import the .dxf file into COMSOL, it appears that not all of the white regions are being detected accurately. Consequently, the flow is occurring in a larger area than intended. I would greatly appreciate any suggestions or advice you may have to help address this issue.
Furthermore, I've encountered situations where, upon importing a geometry, there is no boundary available to assign the concentration in COMSOL. I attempted to address this issue by constructing a rectangle over the image, but this approach resulted in considering both the porous and non-porous media as a single area for flow. As a consequence, I'm currently seeking alternative methods or suggestions to properly assign concentration boundaries in these cases.
I also have another question regarding resizing the geometry that has been built automatically by importing the .dxf file into Comsol. I found that after importing that the geometry is much bigger than the actual image size.
Thank you so much for your cooperation.
Kind regards,
Abdelrazik Elfar
Dear Jeff,
Kind regards,
Abdelrazik Elfar
Jeff Hiller
COMSOL Employee
2 years ago
Jun 8, 2023, 3:07 p.m. EDT
The dxf file used in the pore scale example was authored by a third party, named in the pdf. I would recommend you contact them.
Jeff Hiller
