Octagonal and hexagonal spirals
greetings, I am wondering if there is a way to do hexagonal or octagonal spirals. i searched in COMSOL forum but there is no explicit answer for this. kindly help with this issue
3 Replies Last Post Jun 6, 2023, 1:22 p.m. EDT
Posted: 2 years ago Jun 6, 2023, 8:57 a.m. EDT
Updated: 2 years ago Jun 6, 2023, 9:10 a.m. EDT
Hello Deiaaldeen,
You can create such a spiral by drawing its (hexagonal or octagonal) cross section in a work plane and then sweeping that shape along a spiral curve you will have created using a parametric curve; same idea as in this thread.
By the way, for a quick way to draw regular polygons, see my post in this other thread.
Jeff Hiller
Hello Deiaaldeen, You can create such a spiral by drawing its (hexagonal or octagonal) cross section in a work plane and then sweeping that shape along a spiral curve you will have created using a parametric curve; same idea as in [this thread](https://www.comsol.com/forum/thread/76051/extrusion-along-a-predetermined-path?last=2015-05-18T15:46:19Z). By the way, for a quick way to draw regular polygons, see my post in [this other thread](https://www.comsol.com/forum/thread/157341/randomized-hexagon-using-model-methods?last=2017-10-17T21:27:02Z). Best, Jeff
Posted: 2 years ago Jun 6, 2023, 11:24 a.m. EDT
Hello Deiaaldeen,
thank you for your response, actually i did not find the formulas for the hxagonal nor octagonal spirals. the equations and the paramerters for circular spiral well explained here https://www.comsol.com/blogs/how-to-build-a-parameterized-archimedean-spiral-geometry. but there is no the explaination for the above spirals
>Hello Deiaaldeen, > >You can create such a spiral by drawing its (hexagonal or octagonal) cross section in a work plane and then sweeping that shape along a spiral curve you will have created using a parametric curve; same idea as in [this thread](https://www.comsol.com/forum/thread/76051/extrusion-along-a-predetermined-path?last=2015-05-18T15:46:19Z). > >By the way, for a quick way to draw regular polygons, see my post in [this other thread](https://www.comsol.com/forum/thread/157341/randomized-hexagon-using-model-methods?last=2017-10-17T21:27:02Z). > >Best, > >Jeff thank you for your response, actually i did not find the formulas for the hxagonal nor octagonal spirals. the equations and the paramerters for circular spiral well explained here https://www.comsol.com/blogs/how-to-build-a-parameterized-archimedean-spiral-geometry. but there is no the explaination for the above spirals
Posted: 2 years ago Jun 6, 2023, 1:22 p.m. EDT
Hi again,
You will find the formulae in the file Hexagon.mph attached to my post in the thread I mentioned. In case you are unable to open that file, you can see them in the attached screenshot.
Jeff Hiller
Hi again, You will find the formulae in the file Hexagon.mph attached to my post in the thread I mentioned. In case you are unable to open that file, you can see them in the attached screenshot. Best, Jeff
