1 year ago
Jun 19, 2023, 6:11 a.m. EDT
Updated:
1 year ago
Jun 19, 2023, 6:13 a.m. EDT
At first glance I can see that your physics are not coupled. You have no inlet/outlet BC for the transport of diluted species physics, nor are your transport properties coupled to the flow. Maybe you decided to only solve one physics but that is not apparent from the model you posted.
Secondly, you have a wide range of geometrical sizes which leads to high resolution mesh requirements. This is the warning I obtain upon meshing your geometry:
Number of vertex elements: 38
Number of edge elements: 3111
Number of boundary elements: 83436
Number of elements: 1612463
Minimum element quality: 0.004827
Warning: Low minimum element quality
Do you think this might have something to do with your solution time?
Thirdly, you are not ramping up your boundary condition, as is advised in virtually any COMSOL Blogpost/documentation. Another option would be to solve the turbulent flow first, then use that as the initial solution for you concentration study.
Lastly, I advise experimenting with a simpler geometry, one physics at a time rather than delve into the actual problem immediately.
For reference:
https://www.comsol.com/blogs/viscosity-ramping-improves-the-convergence-of-cfd-models/
https://www.comsol.com/blogs/improving-convergence-multiphysics-problems/
https://www.comsol.com/blogs/how-to-place-inlet-and-outlet-boundary-conditions-in-cfd-simulations/
Kind regards,
Igor
**Warning: Low minimum element quality**
For reference:
Kind regards,
Igor
