Chemical Reaction kinetics, error
this is my first try on Comsol, I am modeling the reaction kinetics of a monolith reactor, using plug flow model for a single channel. there are 3 reactions and 8 components. 2 reactions are at equilibrium and one is irreversible.
I get this error:
Invalid property value.
- Property name: callblevel
- Valid value: One of the strings "nonlin" "optim" "param" "refine" "time".
or a cell vector of such strings. Upper case may be used.
The strings may be abbreviated as long as they uniquely determine
one of these strings.
I do not know which property is this 'callblevel' and how to fix the error.
does anyone know about this error?
Zari
3 Replies Last Post Nov 1, 2012, 1:25 p.m. EDT
Posted: 1 decade ago Oct 31, 2012, 3:45 p.m. EDT
that looks like a strange one, like some typing error ?
But where ?
Are ou working with Matlab or in the GUI ? if the latter, I would say, ask "support" only they really know the interiour.
Another way could be to save the model as a .m file and do a search therein for one of the keywords mentionned, but it's sort of searching in the black ;)
Hi that looks like a strange one, like some typing error ? But where ? Are ou working with Matlab or in the GUI ? if the latter, I would say, ask "support" only they really know the interiour. Another way could be to save the model as a .m file and do a search therein for one of the keywords mentionned, but it's sort of searching in the black ;) -- Good luck Ivar
Posted: 1 decade ago Oct 31, 2012, 4:28 p.m. EDT
I am working with GUI.
I sent an email to support with the attached model file, waiting for the response.
thank you for your reply,
I am working with GUI. I sent an email to support with the attached model file, waiting for the response. thank you for your reply,
Posted: 1 decade ago Nov 1, 2012, 1:25 p.m. EDT
if you can attach your model, I can try to solve you problem. it seems there is some internal typos, have you tried to modify Comsol's default equations.
Hi, if you can attach your model, I can try to solve you problem. it seems there is some internal typos, have you tried to modify Comsol's default equations.
