Can I modify COMSOL solution after it has been computed?
Hello
I am currently working on a reactive transport model in COMSOL, which is coupled with PHREEQC. As part of the verification process, I have been examining the results for each time step. To facilitate this, I have selected 'Steps taken by solver' as the option for 'Times to store'.
The verification process has been successfully completed, and as a result, I no longer need to examine the results for every single time step. Consequently, I am interested in removing the unnecessary part of the solution to reduce the file size of the model. Opening and copying the model file has been time-consuming due to its large size, so reducing the file size would be beneficial in terms of efficiency.
Thanks for reading. If you need any more information, please leave me a comment.
1 Reply Last Post Jul 12, 2023, 2:35 a.m. EDT
Posted: 12 months ago Jul 12, 2023, 2:35 a.m. EDT
Updated: 12 months ago Jul 12, 2023, 2:35 a.m. EDT
Hello
The method of deleting only part of the analyzed result is as follows.
1. Add one more study. Select empty study as the study type.
2. Right-click the added study and select Combine Solutions.
3. Set as follows.
Solution operation: Remove solutions
Solution: Select the appropriate solution
Exclude or include:
Exclude in case of exclusion
Include in case of extracting only the selected area
Include method: Explicit
Time (s): From list
Select only the excluded area or extracted area in the window below, and then select Compute.
Thankyou.
Hello The method of deleting only part of the analyzed result is as follows. 1. Add one more study. Select empty study as the study type. 2. Right-click the added study and select Combine Solutions. 3. Set as follows. Solution operation: Remove solutions Solution: Select the appropriate solution Exclude or include: Exclude in case of exclusion Include in case of extracting only the selected area Include method: Explicit Time (s): From list Select only the excluded area or extracted area in the window below, and then select Compute. Thankyou.
