Kristian Ejlebjærg Jensen
COMSOL Employee
11 months ago
Jul 18, 2023, 2:44 a.m. EDT
freq is the frequency of the solution. There is no variable for the number of the frequency, but if you know the frequency is between 1 and 2 Hz, you can write
if(abs(freq-1.5[Hz])<0.5[Hz],freq,0) as the objective. Then the objective for the other frequencies will be set to zero.
Kristian E. Jensen
Technical Product Manager, Optimization
11 months ago
Jul 19, 2023, 4:45 a.m. EDT
Updated:
11 months ago
Jul 19, 2023, 4:49 a.m. EDT
Thenk you for idea!
But I found an option using functions "withsol" and "setind" from here:
https://www.comsol.com/forum/thread/129793/could-i-use-a-comsol-eigenfrequency-mode-result-as-initial-value-of-a-time-depen
withsol('sol123',freq,setind(lambda,N))
where N - 1, 2, 3 .... is the mode number. I'm not shure that it is correct, but the objective function works correctly and I get the correct fitting parameters.
Despite this, the COMSOL highlights the expression of the objective function in orange and writes a comment: "Unknow variable root.lambda".
Thenk you for idea!
COMSOL Employee
11 months ago
Jul 19, 2023, 5:27 a.m. EDT
That is probably correct. You can disregard the objective warning for special parameters like "lambda". I thought you wanted to perform gradient based optimization where the withsol() operator would give a wrong gradient, but it should work fine for gradient free optimization.
Kristian E. Jensen Technical Product Manager,
Optimization
Optimization
