Robert Koslover
Certified Consultant
2 years ago
Jul 30, 2023, 3:07 p.m. EDT
I've attached an example .mph file that shows one way (among other possibilities) to solve your problem. It's also rather nice to see it yields the correct answer. :)
2 years ago
Jul 30, 2023, 10:21 p.m. EDT
Updated:
2 years ago
Jul 30, 2023, 10:22 p.m. EDT
Thank you Robert. This works excellently. I guess the mistake I was making was that I was trying to define the derivative by substituting α=-1, instead of β=1.
However, I do have a couple of questions which I would appreciate, if you could find the time to answer.
Why does substituting α=-1 (instead of β=1) in the coefficient form PDE not work? If u is a regular valued function, div(u)=du/dx in 1D right?
Why does putting a zero flux condition at x=1 not cause an error, or produce incorrect results.
Thanks in advance,
AR
1. Why does substituting α=-1 (instead of β=1) in the coefficient form PDE not work? If u is a regular valued function, div(u)=du/dx in 1D right?
2. Why does putting a zero flux condition at x=1 not cause an error, or produce incorrect results.
Thanks in advance,
AR
Robert Koslover
2 years ago
Aug 1, 2023, 10:33 p.m. EDT
Let's talk about your seond item first: The (default) zero flux condition (if you look at the equation for it) involves a relationship among linear operations on c, alpha, and gamma. But all of those coefficients are zero, in the example that I posted, so in that case, the "zero flux" condition doesn't impose any constraint.
Now, regarding your first item, if I were to instead set alpha = -1, then I could no longer ignore that default flux boundary condition (per the comment above). There is probably a way to make that still work (since a variety of other boundary conditions are available), but in my approach, that issue simply never arises. I chose what seemed to me to be the simplest approach.
Let's talk about your seond item first: The (default) zero flux condition (if you look at the equation for it) involves a relationship among linear operations on c, alpha, and gamma. But *all* of those coefficients are zero, in the example that I posted, so in that case, the "zero flux" condition doesn't impose any constraint.
2 years ago
Aug 2, 2023, 12:58 a.m. EDT
Thanks Robert. Addresses my queries.
Regards, AR
Regards, AR
