Solver issue in modified Application Example
Posted Aug 16, 2023, 10:53 a.m. EDT General, Studies & Solvers, Modeling Workflow Version 6.1 1 Reply
Hello everyone,
i am rather new to COMSOL and currently working with the Application Example for the Electrostatic Precipitator.
I loaded the given file and then tried some different parameters. I edited the values of the Global 'Parameters1' slightly and added a Value for the temperature. I used this parameter in every Temperature depended simulation.
Now when I try to compute the 'Corona and laminar Flow' simulation I’m getting an Error for X degrees of freedom for variables comp1.u and comp1.v.
X is always a number, but changes as I vary the Parameter list slightly.
Other discussions with this error message recommend checking the material parameters and the boundary conditions, but as I understand I didn't touch either and it worked before.
I would appreciate any help to solve this problem.
