Nov 12, 2012, 2:17 p.m. EST
you need to tell us wha is driving what: is the coil vibrating from an external force, and then you want to induce some signal in the coil (which needs to have some current flowing someway. Or is it the magnetic filed of the coil that is giving a vibrating force on the rod ?
Sort out your variables, then decide for the physics, and sart with the "driving" force/flux
Nov 13, 2012, 6:08 a.m. EST
The magnetic rod is vibrating inside in a static coil.
Finally I want to calculate the voltage induced in the coil due to variable magnetic fields passing through static coil.
The rod is magnetised.
I used the modules: Magnetic Fields and Electrical Circuit and now I want to vibrate the rod.
I need the Structural Mechanics module to add ?
Nagi Elabbasi
Facebook Reality Labs
Nov 13, 2012, 8:41 a.m. EST
Probably not. The functionality in the base COMSOL Multiphysics module should be enough for your vibration analysis.
