Robert Koslover
Certified Consultant
2 years ago
Sep 25, 2023, 10:15 p.m. EDT
Updated:
2 years ago
Sep 25, 2023, 10:28 p.m. EDT
I would like to read a more complete description of your problem. Are you talking about "probes" as they are normally defined in Comsol Muliphysics? If so, a "probe" is simply a variable used to store and track a quantity during program execution; a probe would not normally (i.e., by default) impact the solution of a problem, although it could be used that way. Regardless, what quantity are you probing, and why? You mention the magnetic field, but is that the quantity your probe is sensing/recording? If so, are you perhaps assuming some specific physical relationship between a probe-reported value of a magnetic field and a particular heating mechanism, and you wish to define a coupling between them using the probe reported field value? Regardless, I'm sure you'll receive much better advice on this forum if you can explain to all readers in more detail just what you are trying to accomplish.
I would like to read a more complete description of your problem. Are you talking about "probes" as they are normally defined in Comsol Muliphysics? If so, a "probe" is simply a variable used to store and track a quantity during program execution; a probe would not normally (i.e., by default) impact the solution of a problem, although it *could* be used that way. Regardless, what quantity are you probing, and why? You mention the magnetic field, but is that the quantity your probe is sensing/recording? If so, are you perhaps assuming some specific physical relationship between a probe-reported value of a magnetic field and a particular heating mechanism, and you wish to define a coupling between them using the probe reported field value? Regardless, I'm sure you'll receive much better advice on this forum if you can explain to all readers in more detail just what you are trying to accomplish.
