Use contour plots as geometric entities
Posted Nov 19, 2012, 11:15 a.m. EST Geometry, Results & Visualization 6 Replies
How do you do this?
indeed we are a few on the Forum here interested in this, but havent got/found the trick yet ;)
Perhaps somebody from COMSOl could give us a hint.
It is possible to use contour plots as geometric entities with the following steps:
1. Create a contour plot with a single contour.
2. Add it as a Plot data node under Export.
3. Export the contour data to a text file as a Contour plot with the Sectionwise data format.
4. Add an Interpolation Curve node to the Geometry sequence.
5. In the Interpolation Curve settings, use File as the Data source and Sectionwise as the Data format, and browse to the exported contour data file. Click Build Selected to see the curve. You may need to adjust the Relative tolerance setting to get a smooth curve.
6. When the geometry is rebuilt, the curve is included.
You can add several contours by exporting the data for each curve and adding Interpolation Curve nodes for each contour.
I have attached an image of an interpolation curve for a simple example, using a contour for a level of the solution to Poisson's equation on a square.
Magnus Ringh, COMSOL
Thanks, indeed in 2D it looks simple but not straighforward though, many manual steps, not really to be done for ten models per hours ;) But still thanks for the tip.
What about 2D, the same way with slice plots ?
Josh
Bethany Moatts
COMSOL
it seems like the mentioned link to the step-by-step presentation onhow to do this is no longer existent or inaccurate. Can you help? Thanks, Johanna
I just wanted to add to Magnus's comment that there is now a Model Gallery entry on this: www.comsol.com/showroom/gallery/14235/. If you click "Click here to get more information about this model" on this page you will see a step-by-step presentation on how to do this along with an example model that shows this technique implemented in the power transistor model (the original power transistor model is in the Model Gallery here: www.comsol.com/showroom/gallery/8577/). Note that this same general procedure is applicable for using Contour lines in both 2D and 3D geometries.
Bethany Moatts
COMSOL
Suggested Content
- BLOG How to Include Geometry Surfaces with Solution Plots
- BLOG How to Use Topology Optimization Results as Model Geometries
- BLOG Surface, Volume, and Line Plots: Visualizing Results on a Heat Sink
- KNOWLEDGE BASE Troubleshooting Graphics Issues
- KNOWLEDGE BASE Understanding, and changing, the element order
