How to define a new Anisotropic Creep Law?
Hi all, I want to implement a new creep law in to find the creep behaviour of a pressure tube. The expression for the axial creep rate and transverse creep rate are different and given as,
eps_dot_axial= (E1*sigma_t - E2*sigma_a)*K1*phi +G1*K2*phi
eps_dot_transverse= (E3*sigma_t - E4*sigma_a)*K1*phi +G1*K2*phi
where sigma_t and sigma_a are the transverse and axial stress inside the pressure tube and all others are constants and well known.
How can I define this in COMSOL to get the ansotropic creep strain of the pressure tube?
Thanks for your suggestions.
5 Replies Last Post Oct 21, 2023, 1:05 a.m. EDT
Posted: 10 months ago Oct 16, 2023, 3:43 a.m. EDT
The User defined option in the Creep node allows only isotropic creep. You do however have a possibility to define a general anisotropic creep law by adding an Inelastic Strain Rate node.
If you are working in 3D, select a cylindrical coordinate system. Use the same coordinate system in the parent Linear Elastic Material node, so that you have access to the corresponding stress components.
If you are working in a 2D axisymmetric geometry, the cylindrical system is part of the formulation.
Henrik Sönnerlind
COMSOL
The *User defined* option in the *Creep* node allows only isotropic creep. You do however have a possibility to define a general anisotropic creep law by adding an *Inelastic Strain Rate* node. If you are working in 3D, select a cylindrical coordinate system. Use the same coordinate system in the parent *Linear Elastic Material* node, so that you have access to the corresponding stress components. If you are working in a 2D axisymmetric geometry, the cylindrical system is part of the formulation.
Posted: 10 months ago Oct 17, 2023, 8:22 a.m. EDT
Thank you Henrik for your response. Your suggestion will help me a lot. However I am new to use inelastic strain rate node. Can you please give me more explanations on how to use inelastic strain rate node to define this creep law. Thank you very much for suggestions.
Posted: 10 months ago Oct 18, 2023, 2:24 a.m. EDT
The entries are the components of the strain rate tensor. Essentially, you just have to select the format of the tensor (Diagonal or Symmetric) and then use the expressions from your first posting, but substituted with whatever the quantites would be called in your model. The stresses would be something like
sigma_t -> solid.s22 sigma_a -> solid.s33
Note that you need to provide the full tensor (even though you may decide to set some components to zero, assuming that there is no creep in that direction).
An important aspect is whether the physical creep process is volume preserving or not. If it is, the strain rate tensor must be designed to have that property. For example, the radial strain rate (not mentioned by you), cannot be chosen arbitrarily, since in this case it is required that trace(epsilon_dot) = 0.
Henrik Sönnerlind
COMSOL
The entries are the components of the strain rate tensor. Essentially, you just have to select the format of the tensor (Diagonal or Symmetric) and then use the expressions from your first posting, but substituted with whatever the quantites would be called in your model. The stresses would be something like sigma_t -> solid.s22 sigma_a -> solid.s33 Note that you need to provide the full tensor (even though you may decide to set some components to zero, assuming that there is no creep in that direction). An important aspect is whether the physical creep process is volume preserving or not. If it is, the strain rate tensor must be designed to have that property. For example, the radial strain rate (not mentioned by you), cannot be chosen arbitrarily, since in this case it is required that trace(epsilon_dot) = 0.
Posted: 10 months ago Oct 20, 2023, 12:56 a.m. EDT
Thanks, Henric for your response.I will try it.
Posted: 10 months ago Oct 21, 2023, 1:05 a.m. EDT
Hi Henric, First I described the creep rate equation in the variable subnode. Then use it in the inelastic strain rate tensor, But I am facing many convergence errors. Have a look on my model which I attached. Thanks for your suggestions.
