how to excite coil in 3d
dear all
can you pleas etell em how to excite a coil 3D
kishore Naik Mude
1 Reply Last Post Nov 21, 2012, 6:45 a.m. EST
Posted: 1 decade ago Nov 21, 2012, 6:45 a.m. EST
You can use a lumped port or couple to a circuit physics. Depending on what you exactly need you can use single or multiturn coil domains. There may be more. You can have a look into the examples or tutorial models. In your model it is unclear what the coil should look like.
Cheers
Edgar
You can use a lumped port or couple to a circuit physics. Depending on what you exactly need you can use single or multiturn coil domains. There may be more. You can have a look into the examples or tutorial models. In your model it is unclear what the coil should look like. Cheers Edgar
