Coupling between PDE and Electrostatics
Dear All,
Does any one have any experience of solving a steady general form of PDE with steady electrostaics module. I am trying to solve a PDE [ Div(DuE) = 0] where D is the mobility coefficient and E is the electric field vector that is obtained from the solution of [Lap(V) = 0] in order to solve for the space charge distribution (u) within the domain, however I am not getting any meaningful results at all and in some cases not even a solution. I am using the default UMFPACK solver.
Regards
5 Replies Last Post Dec 26, 2016, 4:00 p.m. EST
Posted: 1 decade ago Nov 22, 2012, 5:08 a.m. EST
I'm doing some simulation with coupling between RF and PDE modules, but it's clueless from your description.
Posted: 1 decade ago Nov 22, 2012, 9:59 a.m. EST
Hi Zang,
Actually I want to solve the PDE simultaneously with the electrostatic module i.e I need to solve the following two equations :
Laplacian(V)=u/eps eq(1)
Divergence(DuE)=0 eq(2)
where E = -Gradient(V)
D is a contant, eps is a constant and E is actually a vector having two components i.e Ex and Ey V is the voltage field and u is the space charge density. However when I try to solve these equations simultaneously by using UMFPACK solver the simulations do not proceed and immediately reports an error of non symmetric matrix found. I simply cant understand what is wrong and how to solve this problem?
Hi Zang, Actually I want to solve the PDE simultaneously with the electrostatic module i.e I need to solve the following two equations : Laplacian(V)=u/eps eq(1) Divergence(DuE)=0 eq(2) where E = -Gradient(V) D is a contant, eps is a constant and E is actually a vector having two components i.e Ex and Ey V is the voltage field and u is the space charge density. However when I try to solve these equations simultaneously by using UMFPACK solver the simulations do not proceed and immediately reports an error of non symmetric matrix found. I simply cant understand what is wrong and how to solve this problem?
Posted: 1 decade ago Nov 22, 2012, 10:02 a.m. EST
It seems the equation system is not complex. But I'm also not familiar with the error message. Perhaps you can upload the model file? I would like to have a look.
Posted: 1 decade ago Apr 11, 2013, 9:44 a.m. EDT
Hello everyone,
I have a convergence problem with modelling of Electrostatics equation coupled with PDE( for charge transport equation). I attached the equations and .mph files.
MODEL : two electrodes placed in domain of air. voltage difference applied. I have to calculate resultant electric field, charge density values and use them to add a body force to laminar flow to simulate plasma.
1. Geometry is simple. Mesh is fine.
2. I tried fully coupled( various damping factors), segregated, parametric sweep of the source term in charge transport equation( which makes it nonlinear) but couldn't get it to converge.
3. I tried using PDEs alone instead of electrostatics,but again same problem ( Plasma Actuator Mod.mph)
Could anyone please help me with way to obtain convergence or any other way to solve the equations attached.
Hello everyone, I have a convergence problem with modelling of Electrostatics equation coupled with PDE( for charge transport equation). I attached the equations and .mph files. MODEL : two electrodes placed in domain of air. voltage difference applied. I have to calculate resultant electric field, charge density values and use them to add a body force to laminar flow to simulate plasma. 1. Geometry is simple. Mesh is fine. 2. I tried fully coupled( various damping factors), segregated, parametric sweep of the source term in charge transport equation( which makes it nonlinear) but couldn't get it to converge. 3. I tried using PDEs alone instead of electrostatics,but again same problem ( Plasma Actuator Mod.mph) Could anyone please help me with way to obtain convergence or any other way to solve the equations attached.
Posted: 8 years ago Dec 26, 2016, 4:00 p.m. EST
You will need to set a voltage as electrical potential in Electronics Initial Values1 (e.g. 1000V).
NK
Hi, You will need to set a voltage as electrical potential in Electronics Initial Values1 (e.g. 1000V). Regards, NK
