field inside the ferrite
Dear all ,
i done simulation of two coils with ferrite core ..in the core magnetic flux lines are not inducing ...can anyone let me the problem
kishore Naik Mude
3 Replies Last Post Nov 22, 2012, 7:34 a.m. EST
Posted: 1 decade ago Nov 22, 2012, 6:51 a.m. EST
pls rreply
kishore Naik Mude
pls rreply -- kishore Naik Mude
Posted: 1 decade ago Nov 22, 2012, 7:31 a.m. EST
You would probably get more response if you were a little more descriptive in your requests. Anyway:
You excluded the soft iron domain from the solution. Look into Results > Data Sets > Solution1 > Selection
Your Magnetic insulation and Axial symmetry boundaries are probably wrong defined.
Cheers
Edgar
You would probably get more response if you were a little more descriptive in your requests. Anyway: You excluded the soft iron domain from the solution. Look into Results > Data Sets > Solution1 > Selection Your Magnetic insulation and Axial symmetry boundaries are probably wrong defined. Cheers Edgar
Posted: 1 decade ago Nov 22, 2012, 7:34 a.m. EST
thanks sir , i am getting now
kishore Naik Mude
thanks sir , i am getting now -- kishore Naik Mude
