Meshing Error
Collins Kariuki Computational Physics (Sustainability)
For the glass substrate model geometry (attached below), I am trying to create a mesh. However, I am encountering this error:
""The current physics settings induce a mesh requirement of about 1.1e+07 elements.
Trying to fulfill this requirement may cause out of memory errors or process locking. Switching to user-controlled mesh.
Please review mesh settings carefully before building the user-controlled mesh, or switch back to physics-controlled mesh and change physics settings.""
Please help me on how I can rectify my physics settings. In my mind, my model is not that complicated, indeed, it's just a slab of Silica glass so I don't understand why the number of elements is that many.
8 Replies Last Post Dec 7, 2023, 2:49 p.m. EST
Posted: 1 year ago Nov 3, 2023, 2:23 p.m. EDT
Updated: 1 year ago Nov 3, 2023, 2:21 p.m. EDT
You didn't attach the file.
Jeff Hiller
You didn't attach the file. Jeff
Posted: 1 year ago Nov 3, 2023, 2:24 p.m. EDT
Here is my mph file.
Posted: 1 year ago Nov 3, 2023, 2:25 p.m. EDT
Updated: 1 year ago Nov 3, 2023, 2:23 p.m. EDT
Attached. Sorry for the delay.
>You didn't attach the file. > >Jeff Attached. Sorry for the delay.
Posted: 1 year ago Nov 3, 2023, 7:01 p.m. EDT
Updated: 1 year ago Nov 3, 2023, 7:01 p.m. EDT
There is still no attached file.
Posted: 1 year ago Nov 3, 2023, 7:43 p.m. EDT
Updated: 1 year ago Nov 3, 2023, 7:42 p.m. EDT
For plate-like structures, often a swept mesh is a good idea.
Posted: 1 year ago Nov 13, 2023, 3:17 p.m. EST
Updated: 1 year ago Nov 13, 2023, 3:16 p.m. EST
Is the .mph attached now? I am really sorry for this delay. I am new to this.
Posted: 1 year ago Nov 13, 2023, 4:19 p.m. EST
Updated: 1 year ago Nov 13, 2023, 4:19 p.m. EST
I don't have the ewfd module, but I can see why you get that error if the software tries to generate a physics-controlled mesh. You are trying to model infrared light (1 micron wavelength) in a computational volume that is a one meter in radius and 5 mm thick. You either need to: (1) model something with a much smaller volume or (2) change your computational method to something that doesn't require resolution on the wavelength scale. Good luck.
I don't have the ewfd module, but I can see why you get that error if the software tries to generate a physics-controlled mesh. You are trying to model infrared light (1 micron wavelength) in a computational volume that is a one meter in radius and 5 mm thick. You either need to: (1) model something with a much smaller volume or (2) change your computational method to something *that doesn't require resolution on the wavelength scale*. Good luck.
Posted: 12 months ago Dec 7, 2023, 2:49 p.m. EST
Updated: 12 months ago Dec 7, 2023, 2:38 p.m. EST
Hello Dr. Koslover. Your advice, specifically (2), worked. Thank you very much.
