Robert Koslover
Certified Consultant
9 months ago
Nov 21, 2023, 6:13 p.m. EST
Updated:
9 months ago
Nov 21, 2023, 6:06 p.m. EST
Have you considered using the mef physics instead?
9 months ago
Nov 21, 2023, 8:45 p.m. EST
Updated:
9 months ago
Nov 21, 2023, 9:09 p.m. EST
Mr. Koslover,
The thought has crossed my mind. However, mef is a little more involved than mf when it comes to the physics. If you could provide a good mef example or detailed explanation that could really help. I'll do my best to describe the setup.
setup
1. 2D model
2. create a Bfield that oscillates at frequency 13MHz.
3. the field will tranverse a ring structure. The inside and outside of the ring will have different electrical properties. If possible the ring boundry will too.
4. Finally, plot the induced electric field in and around the ring. Along with the Bfield.
Any help is much appreciated.
I was thinking if using mf and coil feature to generate the bfield in the frequency domain. I'll see if that works.
Mr. Koslover,
setup
1. 2D model
Edgar J. Kaiser
9 months ago
Nov 22, 2023, 3:06 a.m. EST
Hm, the induced electric field is available in mf. Check the available result quantities.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Cheers
Edgar
