Dec 6, 2012, 4:17 a.m. EST
check the Data Set Join node in the help
Dec 6, 2012, 4:42 a.m. EST
Hi Ivar
thank you. But I forget to tell you , these variables are integration of some other variables in the domain. For example. variable "x1' is for domain 1 and its integration over the domain is 'Y1' similarly for domain 2 . So in this case how can I find the ratio Y1/Y2.
Hi Ivar
Dec 6, 2012, 5:04 a.m. EST
if I understand you can "join" data sets and then access them with a data1() and data(2) special operator (or perhaps you do not need to "join" them, check the "data1(" operator in the help), but in your case you can, from my understanding start to define in (each model if several) a variable for your integration and access the variable with the full name
if you have already a data set and solver case, and you add some integration in the Definition node, and variables, and these are NOT used in the solution, then you can do an "Solver Update solution" per study to get COSMOl to consider these new items. But if you want the solution to depend on some of these new variables, it's better to clear the solution and resolve from scratch
