2D to 3D diffusion Model
Dear all,
I am a new user and would like to ask if there is a possibilty of converting the existing 2D model to 3D model.
Kind regards, Abdelrazik Elfar
1 Reply Last Post Jan 24, 2024, 8:26 a.m. EST
Magnus Ringh COMSOL Employee
Posted: 10 months ago Jan 24, 2024, 8:26 a.m. EST
Updated: 10 months ago Jan 25, 2024, 2:07 a.m. EST
Hi Abdelrazik,
There are several options for transferring some part of a 2D model:
  • You can insert a 2D cross section from the 2D model into a 3D work plane and then extrude it into a 3D volume, for example.
  • You can copy and paste the 2D physics interfaces and materials to the 3D component. Most settings should be OK, but it's likely that you will have to add or modify the selections for boundary conditions etc.
Magnus
Hi Abdelrazik, There are several options for transferring some part of a 2D model: * You can insert a 2D cross section from the 2D model into a 3D work plane and then extrude it into a 3D volume, for example. * You can copy and paste the 2D physics interfaces and materials to the 3D component. Most settings should be OK, but it's likely that you will have to add or modify the selections for boundary conditions etc. Best regards, Magnus
