I don't understand why the ball flies away
Marcus Johansson Certified Consultant
Hi!
I am still beginner for Comsol. When I attempt to simulate, the steel ball flies away from the circular path. I don't know why.
Thanks for the help
1 Reply Last Post Feb 12, 2024, 1:00 a.m. EST
Soumya S S COMSOL Employee
Posted: 1 year ago Feb 12, 2024, 1:00 a.m. EST
As the ball is in contact with the inside boundaries of the outer path, you need to select Use inside boundaries for contact for Rigid Body Contact 1.
Hope this helps.
-Soumya
As the ball is in contact with the inside boundaries of the outer path, you need to select **Use inside boundaries for contact** for **Rigid Body Contact 1**. Hope this helps. -Soumya
