Creating Table using MATLAB command
I want to create a table in COMSOL using MATLAB simulink. I have designed the model with various excitation in each iteration and created the model, however, i am unable to create table from this model for simple voltage, current and resistance calculation.
It is giving an error as **An object with the given name already exists.
- Tag: eval1**
even though I have created an array of eval_param.
please help me to solve this issue:
for i = 1:9 eval_param = sprintf('eval%d', i); tbl{i} = sprintf('tbl%d', i); vol_name = sprintf('mf.VCoil_coil_%d', i); cur_name = sprintf('mf.ICoil_coil_%d', i); res_name = sprintf('mf.RCoil_coil_%d', i);
V_name = sprintf('Coil %d voltage', i);
I_name = sprintf('Coil %d current', i);
R_name = sprintf('Coil %d resistance', i);
% Create numerical evaluation
model.result.numerical.create(eval_param, 'EvalGlobal');
model.result.numerical(eval_param).label(eval_param);
model.result.numerical(eval_param).set('probetag', 'none');
model.result.numerical(eval_param).set('expr', {vol_name, cur_name, res_name});
model.result.numerical(eval_param).set('descr', {V_name, I_name, R_name});
% Create table
model.result.table.create(tbl{i}, 'Table');
model.result.table(tbl{i}).comments(['Global Evaluation', num2str(i)]);
model.result.numerical(eval_param).set('table', tbl{i});
model.result.numerical(eval_param).setResult;
end
0 Replies Last Post Feb 28, 2024, 4:43 p.m. EST
Hello Poonam Chand
