Henrik Sönnerlind
COMSOL Employee
1 year ago
Mar 20, 2024, 9:01 a.m. EDT
If you want to trace a point at a certain location, use a Point Trajectories plot.
If you want to track a certain Point/Line/Surface, add a plot of the same type, set the color to Uniform Red, and add a Selection containing only the intended object. You can then add a Deformation node to make it follow the structural displacements.
Henrik Sönnerlind
COMSOL
If you want to trace a point at a certain location, use a *Point Trajectories* plot.
If you want to track a certain Point/Line/Surface, add a plot of the same type, set the color to *Uniform* *Red*, and add a *Selection* containing only the intended object. You can then add a *Deformation* node to make it follow the structural displacements.
1 year ago
Mar 26, 2024, 1:23 a.m. EDT
thank you very much Dr Sönnerlind
