initial/boundary conditions set as step dependent
In a study with multiple steps, I hope to use different initial/boundary conditions. If initial/boundary conditions can be set as step dependent, all steps can be run in one go during the same study. Can initial/boundary conditions be set as step dependent?
4 Replies Last Post Apr 2, 2024, 10:41 p.m. EDT
Magnus Ringh COMSOL Employee
Posted: 8 months ago Mar 27, 2024, 8:20 a.m. EDT
Hi Carl,
The reply here is the same as the one Henrik gave you to another question:
You can use Modify model configuration for study step in the settings for the study step.
If, however, it is only about having different sets of loads (or constraints), you may find the load case handling functionality more natural.
Magnus
Hi Carl, The reply here is the same as the one Henrik gave you to another question: You can use *Modify model configuration for study step* in the settings for the study step. If, however, it is only about having different sets of loads (or constraints), you may find the load case handling functionality more natural. Best regards, Magnus
Posted: 8 months ago Mar 31, 2024, 1:29 a.m. EDT
Thank you Dr Magnus, where can we find the 'load case handling functionality'?
Posted: 8 months ago Apr 2, 2024, 2:50 a.m. EDT
Take a look at, for example, this model:
https://www.comsol.com/model/tapered-cantilever-with-two-load-cases-12681
Henrik Sönnerlind
COMSOL
Posted: 8 months ago Apr 2, 2024, 10:41 p.m. EDT
that's very helpful thank you Drs Sönnerlind and Ringh.
