Flow Uniformity in microfluidics channels using optimization function
Posted Apr 29, 2024, 8:18 p.m. EDT Version 6.2 0 Replies
Hi Everyone,
I am trying to use the parameter optimization function on comsol to optimize the width of four channels. The goal is to achieve uniform flow rate by varrying the resistance of the channels.
I added boundary probe for spf.u at an equal distance from the outlet and set these boudary probes as the objective functions. Since the objective function doesn't allow a contant value I set the variable for all the boundary probes as such (comp1.bnd1-1e-2)^2. Then I added the pre-defined width parameters (W1-W4) in the control variables and parameters section.
I ran the optimization function using Nelder-Mead method, with minimization function. The width of the channels marginally changed, but it did not achieve uniformity like I expected.
Does anyone know how to correctly set-up the objective function to have all the boundary probes have the exact same value?
Thank you
Hello Ena Qurafi
