On obtaining time values for specific conditions
If I want to get the moment when a certain condition is triggered (e.g. the time when the pressure P>1MPa), what statement should I use; Or I thought about using if(P>1MPa, assign the time t, other) or something like that, but assuming that P>1MPa will continue to rise for a short period of time, then the “time t” will keep changing, and I won't be able to get the first time P>1MPa, is there any way to make the if statement only execute once and then exit, so that the t that I get won't change? Is there any way to make the if statement execute only once and exit so that the t I get will not change?
2 Replies Last Post May 22, 2024, 12:47 a.m. EDT
Posted: 6 months ago May 21, 2024, 5:28 a.m. EDT
Updated: 6 months ago May 22, 2024, 2:34 a.m. EDT
There are two different ways in which I interpret your question:
a) Store the first time at which p exceeds 1 MPa anywhere.
b) For every point in space, store the time at which 1 MPa is exceeded at that point
Both are doable. In either case, the idea is to use a variable which is originally initialized to zero (which would be the default). Then you set it, using an expression of the type
if variable = 0 AND p > 1 MPa
variable = t
else
variable = variable
You will get the time of the first time step at which the reference value is exceeded, which is more or less later than the true time, depending on your time step. There are more sophisticated variants of this scheme which would make an interpolation possible. Then, you would have to use more than one auxiliary variable.
For case a) above, the Events interface can also be useful.
Henrik Sönnerlind
COMSOL
There are two different ways in which I interpret your question: a) Store the first time at which p exceeds 1 MPa anywhere. b) For every point in space, store the time at which 1 MPa is exceeded at that point Both are doable. In either case, the idea is to use a variable which is originally initialized to zero (which would be the default). Then you set it, using an expression of the type if variable = 0 AND p > 1 MPa variable = t else variable = variable You will get the time of the first time step at which the reference value is exceeded, which is more or less later than the true time, depending on your time step. There are more sophisticated variants of this scheme which would make an interpolation possible. Then, you would have to use more than one auxiliary variable. For case a) above, the Events interface can also be useful.
Posted: 6 months ago May 22, 2024, 12:47 a.m. EDT
variable = t
else
variable = variable
You will get the time of the first time step at which the reference value is exceeded, which is more or less later than the true time, depending on your time step. There are more sophisticated variants of this scheme which would make an interpolation possible. The, you would have to use more than one auxiliary variable.
I understood what you meant and managed to get the time I wanted through your method, thank you very much!
>There are two different ways in which I interpret your question: > >a) Store the first time at which p exceeds 1 MPa anywhere. >b) For every point in space, store the time at which 1 MPa is exceeded at that point > >Both are doable. In either case, the idea is to use a variable which is originally initialized to zero (which would be the default). Then you set it, using an expression of the type > >if variable = 0 AND p > 1 MPa > variable = t >else > variable = variable > >You will get the time of the first time step at which the reference value is exceeded, which is more or less later than the true time, depending on your time step. There are more sophisticated variants of this scheme which would make an interpolation possible. The, you would have to use more than one auxiliary variable. > >For case a) above, the Events interface can also be useful. I understood what you meant and managed to get the time I wanted through your method, thank you very much!
