Optimization : force a parameter to be an integer
Hello
I am making an optimization model where I have a repetition of a certain pattern. I want to optimize the overall pattern and the number of repetitions is one of my parameters and I need it to be interger. I guess I could try to use floor(N) in my formulas but I think a gradient descent based algorithm needs some changes between each step to compute the gradient, otherwise it would think that changing N a little does not affect the output. Can someone confirm or denie that ? If that's true, any ideas on how to force this parameter to be integer (force a step of 1) ?
Thank you !
3 Replies Last Post Jun 11, 2024, 4:13 a.m. EDT
Kristian Ejlebjærg Jensen COMSOL Employee
Posted: 11 months ago May 29, 2024, 6:41 a.m. EDT
Updated: 11 months ago May 29, 2024, 6:41 a.m. EDT
COMSOL does not support integer optimization. IPOPT will change controls even though the sensitivity is zero, but in most situations, you can just fix the integer and perform a sweep over the optimization. It sounds like you only have a single integer parameter, so this ought to be a viable strategy.
Kristian E. Jensen
Technical Product Manager Optimization
Hi COMSOL does not support integer optimization. IPOPT will change controls even though the sensitivity is zero, but in most situations, you can just fix the integer and perform a sweep over the optimization. It sounds like you only have a single integer parameter, so this ought to be a viable strategy. Best regards, Kristian E. Jensen Technical Product Manager Optimization
Posted: 11 months ago May 29, 2024, 11:38 a.m. EDT
Updated: 11 months ago May 29, 2024, 11:40 a.m. EDT
Thank you for the reply, I will try that. Is the incrementation of each parameter constant over the optimisation ? if so I could maybe find a scale factor that makes the step be 1
Posted: 10 months ago Jun 11, 2024, 4:13 a.m. EDT
Updated: 10 months ago Jun 11, 2024, 3:02 p.m. EDT
You can specify the increment in the Parametric Sweep, i.e. range(1,1,10) sweeps the value from 1 to 10 in steps of 1.
Kristian E. Jensen
Hi You can specify the increment in the Parametric Sweep, i.e. range(1,1,10) sweeps the value from 1 to 10 in steps of 1. Best regards, Kristian E. Jensen Technical Product Manager Optimization
