Geometry visualization
Hi all,
I have a comlex geometry in 3D, which is not suitable for simplification. I have to model a wire of a coil together witz its insulation. The wire has a dimension of some mm while the insulation is 0.2mm. The total dimension of the model is about 400 mm. Now I get errors during meshing, including selfintesecting boundaries.Is there a (easy) way to find these "error" boundaries? Or is it possible in preprocessing, to cut the model and see only the geometry on this cutplane.?
Does anybody has some suggestions
Uwe
1 Reply Last Post Jan 15, 2013, 12:48 a.m. EST
Posted: 1 decade ago Jan 15, 2013, 12:48 a.m. EST
it's often useful to cut a geometry, i.e. through 1-3 planes, and if you have some symmetry, manually mesh using this local symmetry
Hi it's often useful to cut a geometry, i.e. through 1-3 planes, and if you have some symmetry, manually mesh using this local symmetry -- Good luck Ivar
